vibes
davy thomson
vibes
#1 PostAuthor: davy thomson » Fri May 16, 2008 6:35 am
My mates 1100r is suffering from bad vibes through th bars, any clues to help cure this. :?:
1000 posts reached that will do for me,over and out.been fun.
#2 PostAuthor: chrisNI » Sat May 17, 2008 12:12 am
Davy when's it doing it? Is it when it's sitting still ticking over, or at low speed moving or what?
floydsz1
#3 PostAuthor: floydsz1 » Sat May 17, 2008 12:47 pm
It can help by putting some lead in the handlebar ends, modern bikes have bar end weights to help cure the vibes.
Big John
#4 PostAuthor: Big John » Sat May 17, 2008 6:02 pm
1100R's should have bar end weights fitted as standard.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
davy thomson
#5 PostAuthor: davy thomson » Fri May 23, 2008 6:44 pm
Chris the bars vibe on the road and sitting ticking over,it has the bar end weights in place John. :)
Big John
#6 PostAuthor: Big John » Fri May 23, 2008 6:48 pm
Could be carb balancing, has the bike been standing?
davy thomson
#7 PostAuthor: davy thomson » Fri May 23, 2008 6:57 pm
The bike has been sitting John might give that a try,its due a servce any how what oil do you use in your bike John.
