Cam End plugs - Cylinder Head rebuild
Hi, on an old and hard set of rubber plugs I had to use silicone gasket just to keep them in place, than got a new set and these were tight fit , no silicone and no leaks either, finally I got APE alloy ones, all four are the same size but two fitted to one side had to be filed quite a lot as were too high,got mine polished too, good thing is that job has to be done once than silicone them in and should stay forever, agree with Pigford they do look quality
Users browsing this forum: Bing [Bot] and 78 guests
