compression deppression
Hi fellas, after rebuilding the motor on the Z1B we noticed a bit of smoke out the exhaust on a recent run. The bike has only 200 miles on the engine, it had the heads recond. new rings, but the bore was only honed. I did a compression test and got a reading of only 90 PSI per cylinder, squirt of oil made no difference. The local mech. says it still needs time to bed in. What do you think??
Users browsing this forum: Maunders and 33 guests
