Professional carb cleaners ?
bunnysZ
Granny Magnet
#1 PostAuthor: bunnysZ » Wed Nov 15, 2006 8:20 pm
have some old dirty carbs need cleaning.. people have mentioned they get theirs ultra sonicly cleaned..(or something like that)
can anyone recommend someone to me.
the nearer to watford or hertfordshire the better.
cheers
london calling
#2 PostAuthor: london calling » Wed Nov 15, 2006 8:40 pm
Ring round your local bike shops,maybe a carb specialist or dyno centre would have an ultra-sonic cleaning tank.Most automotive engineering firms will have them to get metallic parts perfectly cleaned.
The carbs have to be stripped,all jets removed,etc so it is quite a labour intensive process but the results are worth it.
I'm getting some done for "Bling Master" Dale and i'll be down to see him soon in Harlow,so if you don't have any luck locally maybe i can help you out.
What carbs are they?? :cool:
Jack
bunnysZ
Granny Magnet
#3 PostAuthor: bunnysZ » Wed Nov 15, 2006 9:05 pm
they are 26mm mikuni carbs.. stripped down .... no rush so will search and ring around.....if no joy will give you a shout ...cheers jack
Magik
#4 PostAuthor: Magik » Fri Nov 17, 2006 7:46 pm
Ultrasonic cleaners are reasonably cheap to buy, 'seen um on Fleabay for around fifty quid...gotta be worth buying and trying yourself for that sort of money, what's a specialist going to charge? :)
london calling
#5 PostAuthor: london calling » Fri Nov 17, 2006 7:56 pm
Just make sure they're big enough to be able to take a complete bank of carbs. :cool:
Jack
Padders
#6 PostAuthor: Padders » Fri Nov 17, 2006 8:37 pm
JRS have a good reputation for this work and can be contacted on 01792 402458 website www.jrs.uk.com or e mail ultracleancarbs@jrs.uk.com
Ian.
PUM 13
steve
#7 PostAuthor: steve » Fri Nov 17, 2006 11:29 pm
I've used a company called 'Carb Exchange' on 01525 371369 based in Leighton Buzzard. They do an excellent job and bring the carb bodies back to just about how they looked when new, ie. a natural 'gun-metal' finish. Some carbs that I've seen end up far too shiny...but still, it depends on what you are looking for. Carb Exchange charge approx ?9 per carb...by the way, don't be put off by the name...they don't actually exchange your carbs for some they already have, it's yours that are chemically cleaned.
Hope this helps.
Steve
Jeff Saunders
#8 PostAuthor: Jeff Saunders » Sat Nov 18, 2006 1:12 pm
Ultrasonic cleaning can be good - one caution, all moving parts should be removed from the carbs. If you leave float needles in the seats, the vibrations will damage the seat and needle. You can have the same problem with the needle / needle jets, accelerator pump parts, etc.
steve
#9 PostAuthor: steve » Sat Nov 18, 2006 2:24 pm
Yes. agree Jeff...whatever method of carb cleaning is decided upon, every last piece needs to be removed from the carb bodies.
Steve
Steve S
#10 PostAuthor: Steve S » Sun Nov 19, 2006 12:16 am
Hi Steve,
You gave me carb exchanges number at the Stafford show,spoke to them was quoted about ?7 a body.
Have just stripped my carbs down tonight ready to send off soon, cheers for the contact will keep all posted as to the results.
bunnysZ
Granny Magnet
#11 PostAuthor: bunnysZ » Sun Nov 19, 2006 9:28 am
I phoned them up quoted ?7 aswell, carbs stripped and taking them up there this week. steve if you are anywhere near watford on route to buzzard I can collect yours and take them for you. save postage.
how long does the process take, can i wait or do i have to return another day..?
Steve S
#12 PostAuthor: Steve S » Sun Nov 19, 2006 12:45 pm
Cheers BunnyZ,
Didnt ask how long it takes to do,presumed I would drop off and pick up at a later date, will have to find out.
I shouldnt think it takes long to do depending on their workload I didnt fancy posting them what with Xmas looming!
I,m in Reigate which is about 45min from Watford might be able to sort something out to share the travelling,when were you thinking of going?
Are you doing float bowls as well?.
Steve s
steve
#13 PostAuthor: steve » Sun Nov 19, 2006 3:25 pm
Carb Exchange usually take a week or two. I'm pretty sure they use a courier company if you wanted to have them sent back to you, which I seem to remember cost around a tenner.
I've used this before without any probs.
Steve
bunnysZ
Granny Magnet
#14 PostAuthor: bunnysZ » Sun Nov 19, 2006 6:49 pm
steve s
i have sent a message/pm to you
Users browsing this forum: Bing [Bot] and 26 guests
