Switch gear
Switch gear
Ok chaps i require the bottom portion of the Left hand switch gear that incorporates the HAZARD light switch not worried about switches,but need the cable clamp and it must be the type where the cables exit(not into but) along the handlebars. Thanx in advance.
- mick znone
- paul doran
Re: W.O.T
ted1r wrote:CAN YOU HANG ON THAT FAST
Ted in Piglet's case it's WOG
wide open gob
- paul doran
ed
ed ive' got left hand switch bottom for z1r
pm me and ill' send you pics to see if its right,
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
