not another lawson!!
RoyNorway
#16 PostAuthor: RoyNorway » Fri Jul 11, 2008 2:24 pm
57 varieties? :lol: :lol:
Nice project, keep the pictures flowing... :P
Those fasteners for the shocks, are they these ?
I also will start on using the word egay i think... :twisted:
Z1000J 82 model, and Z1000R 83 model, And The Calfshit-GPZ1100-
kawaman21
#17 PostAuthor: kawaman21 » Fri Jul 11, 2008 8:02 pm
i got the shock mounts made and welded on by spondon about 12 years ago
RALPHARAMA
#18 PostAuthor: RALPHARAMA » Fri Jul 11, 2008 10:28 pm
RoyNorway wrote:57 varieties? :lol: :lol:
How do you do the one word links? I know how to do it with html in Dream Weaver but haven't a clue in a bucket how to do it on here :?? Thanx :D
Ralph Ferrand
RoyNorway
#19 PostAuthor: RoyNorway » Sat Jul 12, 2008 9:57 am
The linking is easy. When you know :twisted:
When you write a new reply you got some square buttons on the top.
Put the arrow on URL box and it looks like this:
Just above here now its a line who says ;
What I do is highlight , right click and "copy", this string of it;
Then you right click and "past" it in the writing field here.
Then you just fill in the URL address of the page you want to link to where it says "http://url" and your comment or what you will call it there it says "URL text". You have to remove whats in there before you do it.
So then it could be like this:
And the result is only what says here:
My old Z900 back in 1991
This is what I have written now, before I click the "Submit" button:
Hope its make it clearer, otherwise ask, and sorry for the offtopic kawaman21! :lol:
kawaman21
#20 PostAuthor: kawaman21 » Sat Jul 12, 2008 11:03 am
fecking hijacker,it's all geek to me
(no offence to our geek members) :lol:
isn't pc alot of sh#te
kawaman21
#21 PostAuthor: kawaman21 » Sun Jul 13, 2008 8:16 pm
fitted my spondon race disc's,6mm thick fullyfloating nice rattle over bumps,just need to find all my disc bolts,or get new stainless ones,aaaaghhhh the expense of it all,it 's more than a poor scotsman can take.Image
[/img]
#22 PostAuthor: chrisNI » Mon Jul 14, 2008 3:30 pm
Nice discs.... :sou
kawaman21
#23 PostAuthor: kawaman21 » Wed Jul 16, 2008 9:51 pm
bit more progress today,fixed the oil leak on no.1 bike,different oil take off's don't know the make(any idea's)got them from drag racer pip higham.
need to buy a proper fitting to connect one line as it is too short now.
i used a tube and jubilee clips just to run the motor to check for leaks :oops:
fitted some body work to heinz,this tank need's a pingel tap and it will probably end up on the other as the paint is better
here are some pic's.
[img][img]http://i315.photobucket.com/albums/ll457/kawaman21/th_IMGP0420.jpg[/img]
Image[/img]
kawaman21
#24 PostAuthor: kawaman21 » Fri Jul 18, 2008 3:12 pm
had a delve into the motor today,took off the MDF cover that was on the sump and had a butchers around the crank and gearbox.
it's nice and clean inside ,dogs and forks look good and the cogs look in good condition(though i am no expert).found another piston has been bashed against the cases,and dented the piston so that is for the bin.
started up no1 bike and petrol started pissing out of no2 carb ahh the joy's :lol:
some pictures
[img][img]http://i315.photobucket.com/albums/ll457/kawaman21/th_IMGP0470.jpg[/img]
[/img]
#25 PostAuthor: chrisNI » Fri Jul 18, 2008 4:19 pm
Is that a Kawasaki back wheel?
kawaman21
#26 PostAuthor: kawaman21 » Fri Jul 18, 2008 10:11 pm
yip it's a zrx11 wheel
RoyNorway
#27 PostAuthor: RoyNorway » Sat Jul 19, 2008 5:47 pm
Looks nice. :lol: :lol:
That zrx wheels are indeed nice, maybe thats the route for me to go on the 1000R.
kawaman21
#28 PostAuthor: kawaman21 » Fri Feb 27, 2009 9:24 am
not had much to report of late,bought a house so the bikes have been on the back burner.
got some shocks from a xjr 13 not pukka ohlins but they are better than the metal struts!!
need to get aproper garage also,though the bike looks ok in the diningroom for now :D
will probably use the no.1 bike this year,its been a while
might see some of you at the scottish show,it's only a couple of weeks away.
kawaman21
#29 PostAuthor: kawaman21 » Mon Mar 02, 2009 8:38 am
some pic's i hope
kawaman21
#30 PostAuthor: kawaman21 » Tue Apr 21, 2009 12:50 pm
not much to report lately.fitted some zrx 11 yokes,to get rid of the too high risers,the forks touch the tank on full lock,which doesn't happen with 1200 yokes,so have to sort that.
main problem is the budget is blown now i have bought this...
