Help with Electrics please
Big Glenn
#1 PostAuthor: Big Glenn » Mon Jul 14, 2008 7:29 pm
Does anyone know if the ignition switch for a US spec Z1000 is different to the UK one? the problem I have is when I turn on the ignition switch it does not supply power to the 2 auxillary fuses, so cosequently I cannot get any power to the lights.
Any suggestions gratefully recieved.
#2 PostAuthor: Pigford » Mon Jul 14, 2008 9:40 pm
Not 100% sure, but the Yanks have 'running' lights & fings.... so could well be different :cry:
Big John
#3 PostAuthor: Big John » Mon Jul 14, 2008 9:47 pm
Don't think the lights light up until the engine is running.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
Big Glenn
#4 PostAuthor: Big Glenn » Tue Jul 15, 2008 4:29 pm
Panic over!! found the problem, it was a bad connection on the 9 pin connector behind the clocks, and headlight.
So now I can continue with the rebuild, i.e wiring the lights and indicators etc.
Thanks.
