PostPosted: Sun Aug 31, 2008 10:45 am Post subject:
Al, ditch those CV carbs.... you'll never get them sorted....
Proper slide carbs are the only way to go
FER
PostPosted: Sun Aug 31, 2008 10:55 am Post subject:
The J carbs have a filter fitted to each carb above the float needle . Remove the screw and holding plate then pull out the float needle seat . You will be amazed at how much crap is on the filter . Remove all 4 and blow out the passage way with an air line . It only takes a small bit of crap to allow fuel to flow past the needle .
PostPosted: Sun Aug 31, 2008 1:53 pm Post subject:
The reason it says do the fuel heights with the engine running is because the fuel tap is vacuum operated. As you have replaced this with a manual one you shouldn't need to burn your fingers so much as you do not need the engine running Wink
PostPosted: Sun Aug 31, 2008 6:55 pm Post subject:
No offence meant Al Wink
I found this thread very interesting, good show Very Happy
PS: i managed an 11.5, so a good 1/2 second + better Twisted Evil Laughing
Zorded have a word with your local Scotoiler supplier about the scintered balls they use to smooth the pulses in their vac take off leads, they may act as dampers for you.
Users browsing this forum: No registered users and 73 guests
