standard clocks
brian 450
standard clocks
#1 PostAuthor: brian 450 » Thu Sep 11, 2008 9:02 am
hi all, if i put a 17'' front wheel in z900 is it posable to get the speedo recalabrated?
phil churchett
#2 PostAuthor: phil churchett » Thu Sep 11, 2008 11:05 am
Not sure, but Chris Rivett is the person to speak to.
His no is in the Services section of the club magazine.
#3 PostAuthor: Pigford » Thu Sep 11, 2008 5:24 pm
Brian,
I had one of those kph - mph converted gear box thingy-ma-gigs on me old Gixxer...... :lol:
That slows down the revolutions from the wheel to fool the kph speedo & therefore you can read it as mph :wink:
This will have the same effect, so if you fit a 17" wheel....
Won't be spot on but not far out.
I can't be arsed to calculate the difference :??
Pasc
#4 PostAuthor: Pasc » Thu Sep 11, 2008 6:29 pm
Pigford wrote:I can't be arsed to calculate the difference :??
1 kilometre = 0.6 miles
#5 PostAuthor: Pigford » Thu Sep 11, 2008 6:47 pm
Pasc.... :roll:
Wot I meant woz.... compare the difference between the gearing of the kph - mph, against the difference between the circumference of the std 19" wheel vs the 17" wheel :?? To see how near it would be :shock:
Users browsing this forum: No registered users and 84 guests
