trick z1000
Gus
#16 PostAuthor: Gus » Fri Sep 05, 2008 9:59 am
brian 450 wrote:thanks for all your help lads, its going to be a long 2 weeks any chance of some pics of the 180 conversion
Complete Bandit 1200 rear end
"Set the GRINDER on it"
brian 450
#17 PostAuthor: brian 450 » Fri Sep 05, 2008 11:37 am
Now thats a idea i have got a bandit in garage!! My other project is in MCN competition biking britain got talent at mow, been in Dec Streetfigters, and its going in 2009 Crossbow calendar. if any one fancys a look on MCN web its under (my streetfighter R1) :wink: brian
#18 PostAuthor: Pigford » Fri Sep 05, 2008 11:54 am
This is very nice.....
Me very own 180 x 17 :twisted:
brian 450
#19 PostAuthor: brian 450 » Fri Sep 05, 2008 12:09 pm
That looks the Bollox!!! thats how want my one to look :evil: is the engine tuned?
brian 450
#20 PostAuthor: brian 450 » Sun Sep 14, 2008 8:02 pm
Been to see z its a bit rough needs a bit of tlc. got big carbs, k+n filters, looks like a fast flow fuel tap, the owners not sure but he thinks its been tuned because its a lot quicker than his old z. rizmola rear sets metamex arm, alloy spoked wheels of some sort, nearly new ohlins shocks harrison billet calipers on front, its not a z1000 after all it's a 1975 z900 going by frame no. No badges kawasaki painted on tank does any one know if i could put them back on? £1500 is that about right?
PJones
#21 PostAuthor: PJones » Sun Sep 14, 2008 9:08 pm
brian 450 wrote:Been to see z its a bit rough needs a bit of tlc. got big carbs, k+n filters, looks like a fast flow fuel tap, the owners not sure but he thinks its been tuned because its a lot quicker than his old z. rizmola rear sets metamex arm, alloy spoked wheels of some sort, nearly new ohlins shocks harrison billet calipers on front, its not a z1000 after all it's a 1975 z900 going by frame no. No badges kawasaki painted on tank does any one know if i could put them back on? £1500 is that about right?
Hi Brian it sounds o.k., difficult to say without seeing the bike, surely he knows if the engine has been upgraded?
PJ
WHO NEEDS DRUG'S
brian 450
#22 PostAuthor: brian 450 » Sun Sep 14, 2008 9:19 pm
no he bought it off a old boy he met when he went round his house to do a job they got talking about bikes and this one was the chaps sons who had got ill. so he bought it prob for next to nothing :twisted:
CRISPY
#23 PostAuthor: CRISPY » Mon Sep 15, 2008 4:45 am
Brian this is mine an A4 but now in bits again putting 180 in rear and upsidedowners in front
Crispy
brian 450
#24 PostAuthor: brian 450 » Mon Sep 15, 2008 7:37 pm
found out what it is! Z1B with Z1000 engine that might be tuned a bit. is that any good?
#25 PostAuthor: Pigford » Mon Sep 15, 2008 8:49 pm
BRIAN, GOOD TO MEET YOU AT THE pod OVER THE WEEKEND..... :wink:
My bike is a 1075, gasflowed, RFS36 carbs... etc. Its good enuff for 11.5 over the 1/4 so not too bad for a 30 yr old machine :wink:
Any old Zed can be as GOOD or BAD as you want - how deep yer pockets then ££££££££'s :?:
rickman CRR
#26 PostAuthor: rickman CRR » Wed Sep 17, 2008 5:18 pm
http://www.debben.co.uk/acatalog/Z900.html
530 or 630 pitch
10 or 15mm off-set
15,17 or 18 teeth
£45 plus VAT
KWACKERZ1
#27 PostAuthor: KWACKERZ1 » Wed Sep 17, 2008 7:45 pm
Brian,
Generally if it has got big carbs on especially as big or bigger than 33mm's and it runs ok there is a fair chance its had a big bore as often the big carbies dont suit standard engines.
Although if they are 29mm ones they would be about right and offer extra performance, its relatively easy to rip the carbs off (and check!).
If it has 29mm cr's then they are also pretty rare.
With regard to Bracing,
I will post the instructions and measurements for frame bracing later on the forum, but need to get my scanner connected first.
Phil
KWACKERZ1
#28 PostAuthor: KWACKERZ1 » Wed Sep 17, 2008 7:46 pm
Brian,
Phil
#29 PostAuthor: Pigford » Wed Sep 17, 2008 7:48 pm
brian 450
#30 PostAuthor: brian 450 » Wed Sep 17, 2008 9:22 pm
Thanks for that phil. should be able to get it at weekend once shed has been cleared, then i can look at carbs. at mate of mine is going to measure cams ect to find out if it has had any work done on it. will try to post some pics when i get it. brian
Users browsing this forum: No registered users and 158 guests
