carb float heights - Help needed on how to check the heights
crossy2425
#1 PostAuthor: crossy2425 » Thu May 04, 2006 10:32 pm
Hi,
Please could someone describe the best/easiest way to check the float heights on a Z650?
Slide carbs. Manual says 30mm. Where is this measurment taken from?
Many thanks.
(Edited by crossy2425 at 11:33 pm on May 4, 2006)
#2 PostAuthor: chrisNI » Fri May 05, 2006 6:16 pm
If the set-up's the same as the other Zeds the best way to do the float levels is to get a tool made up like the one in the manual with a tube that screws into the bottom of the float bowls. You can then measure off a point on the carb.
