Instant Gasket Removal
tlc
#1 PostAuthor: tlc » Sun Oct 26, 2008 11:47 am
Sadly too bad to go out today so I`ve started on the carburettor rebuild on my Thou`.
Someone has used Black gasket Goo around the intake rubbers previously and I need to get rid of it before I clean the carbs up.
Any ideas on the best way to remove it ? Bearing in mind it`s on a rough casting so sticks like sh*t to a blanket !
mikey
#2 PostAuthor: mikey » Sun Oct 26, 2008 12:11 pm
What ive used before chris for this is paint thinners and a stiff nylon brush bit tedious but it worked for me.
tlc
#3 PostAuthor: tlc » Sun Oct 26, 2008 4:12 pm
Thanks Mikey.
Just the job :)
steve f
#4 PostAuthor: steve f » Mon Oct 27, 2008 8:06 am
they do sell gasket remover in a spray can :D
02GF74
#5 PostAuthor: 02GF74 » Mon Oct 27, 2008 2:34 pm
hmmmmmm black gasket goo??? never seen it come in black, not that I am some sort of gasket goo spotter. ... but it could be silicone sealant?
you can buy silicone sealant remover in tubes, places like homebase sell it.
tlc
#6 PostAuthor: tlc » Mon Oct 27, 2008 5:27 pm
Yes it`s black silicone instant gasket. Thanks for the tip but I got some thinners and that seems to be doing the trick just now.
It`s also a lot more powerful than Red Wine :pist
#7 PostAuthor: Pigford » Mon Oct 27, 2008 6:54 pm
Permatex "Ultra Black" is a top quality sealent made in the US of A....
They do grey & other colours too..... as used & recommended by Debben Performance... although they don't necessarily say on manifold rubbers :wink:
I also use the Copper Permatex on the barrel 'O' ring channel when using a 1-piece gasket :wink:
