Wanted:73-75 Rear Brake Rod Pin
MaineKZ
#1 PostAuthor: MaineKZ » Thu Nov 20, 2008 8:03 pm
I need the cylindrical 'Pin' (with the unthreaded hole through it's centre) that fits into the end of the brake hub lever. The brake rod passes through it, held in place by spring and adjuster nut. You know - that thing! It's item number 38 on page 26 of the Z-Power parts book.
My original seems to have dissolved somewhat - didn't realise it was pot metal rather than mild steel so didn't respond well the an acid bath!! :oops:
Little Kwacker Curveball there :roll:
Taaa
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Fri Nov 21, 2008 5:56 am
MAINEKZ
TRY KLASMO BIKES,THEY STILL LIST THEM,I THINK THEY ARE ON FRAME SECTION,JUST ORDERED SOME MYSELF,THEY ARE A LITTLE SLOW WITH DELIVERIES BUT THE BITZ TURN UP EVENTUALLY
REGARDS
STEVE
floydsz1
#3 PostAuthor: floydsz1 » Sat Nov 22, 2008 3:00 pm
Thought i had a spare one you could have had but cant find it. jeff at z1enterprises sells them ,
http://www.z1enterprises.com/detail.aspx?ID=1918
