trick z1000
Brian,
Who did the fork extensions for you and how much did they cost as I have a set of forks I could do with extensions for and yours look really good and simple.
I know I could get maxton to do them and re-spring the forks but we are looking at about £500 which I cant stretch to at the moment.
Phil
Phil
- paul doran
Pigford wrote:TLC, 5 minutes is more than enuff for me to have a good fiddle...![]()
I only use a paddock stand... best way coz the suspension is loaded, & chain tension can be better assessed for correct tension....![]()
Stick with it TLC, you'll get there mate![]()
Piglet uses the ironing board when adjusting his chain
oh that's the chain around his neck by the way
p://i435.photobucket.com/al
bums/qq76/Stigsstuntdouble/001.jpg[/IMG]
