Front Brake Discs
Front Brake Discs
I am going to fit some different callipers to my Z900. This will really require me to fit floating discs. Apart from buying from Z Power or EBC which will be around the £300 mark. Is it possible to fit discs from another bike whilst still using the standard forks etc.
LE to JOG on a z900
P.U.M.
P.U.M.
I have been told if the disc dont float or the calipers dont slide the discs will wear quicker.
I bought a zed with a standard discs and modern fixed calipers and the discs dont look to be to bad.
At the end of the day I'd mount them on and try it if all else fails then you can always buy floating discs.
(My discs had to be spaced out though for the spokes not to hit the back of teh calipers)
