right hand side caliper for z1
hillbilly
#1 PostAuthor: hillbilly » Sun Nov 30, 2008 4:11 pm
i need a right hand side caliper for my z1,i say the right hand side,as you are sitting on it,just won some forks on ebay,now need brakes,someone must know were there is one. :wink: :wink:
000zeds
#2 PostAuthor: 000zeds » Sun Nov 30, 2008 5:45 pm
Z1 forks always have the fitting for 2 brake calipers ? Z-Power do the complete kit to change from single to double disc !
Zeds-R-Us
tlc
#3 PostAuthor: tlc » Sun Nov 30, 2008 5:47 pm
F ing expensive though !
Is it a Z1 or Z900 ?
hillbilly
#4 PostAuthor: hillbilly » Sun Nov 30, 2008 8:30 pm
its a 1973 z1 900.ive got the forks to have twin calipers now,just need the right hand side one as you look forward over handle bars. :(
000zeds
#5 PostAuthor: 000zeds » Sun Nov 30, 2008 9:05 pm
What forks did you have before as all Z1s , Z900s have mountings for two calipers !
Zeds-R-Us
foreverinthegarage
#6 PostAuthor: foreverinthegarage » Sun Nov 30, 2008 10:39 pm
Hi Do you need a calliper with a hose or steel pipe
Regards Mick.
Z1000 The King Is Still Alive.
gbh
#7 PostAuthor: gbh » Mon Dec 01, 2008 3:09 am
You don't actually need the entire caliper. All you need is the carrier, PMC make a repro carrier that retails here for around 9000yen. Then you will need the right hand pipe which is also still available from Kawasaki...then of course the rubber hoses if you don't already have them.
fredswat
Twin Discs
#8 PostAuthor: fredswat » Mon Dec 01, 2008 12:13 pm
I have converted my Z1B to twin Discs
You will need
RH caliper mtg Brkt - Z1 Enterpises do them
additional caliper & disc
Dual brake hose splitter & brake stop lamp switch assembly
additional hose & metal pipe (from splitter to caliper )
RH hose brkt - Mounts between forks and front fender
5/8 bore master cylinder as the single disc one is not up to operating 2 discs
tlc
#9 PostAuthor: tlc » Mon Dec 01, 2008 5:34 pm
hillbilly
#10 PostAuthor: hillbilly » Mon Dec 01, 2008 5:45 pm
struthe lads,do i need a better paying job,i think i need the one with iron pipe,the forks i have are off a z thou ,just got a set of forks with the chrome reflectors on ebay,and would like the caliper on the usa ebay,as that one would pair up to the one i already got. :shock: :roll: :o
