pro-stock aspirations/project big bang!!!
rafstopcarryon
hi,big green bus.......... a 2v (stock head) like this although very highly modified, is for pro stock bike purposes.......obsolete,with about 220-230bhp,that'll be good, i would imagine for 8:0's?(all motor) the 4v'ers have suffered the same as the early 2v and have hit their limit,so everyone moved back to the 2v combo allbe-it with the ward/vortex top-end 50mm titanium valves,700 plus lift cams,special buckets,50mm lectrons(modified) 89mm pistons(modified).......the list goes on(well as far as yeh wallet will allow)
but a motor like this,as long as it stays together,will get me going again,practice makes perfect and all that
rafstopcarryon
i'll tell yeh when it's been on a dyno......
but there's a limit,(that's down to the head) as to the bhp achievable from the kawasaki setup(240+? maybe that optomistic),thats why schultz jumped ship back in the day,pete briggs reckoned on about 300bhp@1500cc from his kawasaki with the vortex head,and that was the next limiting factor between suz/kaw was the 85mm(1500cc) limit of the kawasaki cases........but now
raf
raf
rafstopcarryon
when i say 240bhp plus,that'll be with every modification done to the head you can think ov..............................and more,8 plug conversion with surface discharge plugs,titanium valves,cams moved within head(allowing bigger valves
) welded in bridges to strengthen,welded and epoxied straight ports,one off cams,magnesium rocker cover
- big green bus
rafstopcarryon
rafstopcarryon
- london calling
- london calling
rafstopcarryon
- london calling
- ade woollams
so london calling is this V&H PIPE the start of a new project. or is it all thats left of raffs.
another cylinder head,gives you the idea of the sort of valves needed for this application
