Pigfords OLD effort......now JULES NEW PROJECT!!!!!
#166 PostAuthor: Pigford » Fri Jan 09, 2009 12:29 pm
paul doran wrote:Piglet you got it half right
were those your jim jam's you were wearing :lol: :lol: :lol:
I was wearing my boiler suit - which has my name on them... :wink:
Al, must admit, Ray did seem a bit faster than I remember, but not that much :twisted:
Gotta tighten exhaust (blowing here & there) set ignition (as I guessed it for the initial start up).
I have used Tesco basic mineral (20-50w) to run it for a few miles, then will put in new oil & filter :P
Got some nice K&N's off Noel McGuinness which will be added :wink: Waiting for some s/s lines from M&P to do brakes :shock:
Can't waint to go for a spin :lol:
Padders
#167 PostAuthor: Padders » Fri Jan 09, 2009 1:57 pm
Looks good Mark can't wait to see it in action.
#168 PostAuthor: paul doran » Fri Jan 09, 2009 5:51 pm
Pigford wrote:
Exhaust & stuff is just cobbled together for the moment... but ran her for a couple of minutes... :wink:
somehow the words cobbled together and Piglet go hand in hand :lol: :lol:
#169 PostAuthor: Rich » Fri Jan 09, 2009 6:12 pm
That's really nice Mark - will you be leaving the calipers on or taking them off to ride it :?: :twisted: :twisted: :twisted: :twisted: :twisted:
#170 PostAuthor: Pigford » Fri Jan 09, 2009 6:20 pm
:roll:
Front caliper'S
#171 PostAuthor: Rich » Fri Jan 09, 2009 6:26 pm
Taking them off I see :lol: :lol: :lol: :lol: :lol:
ted1r
BIKE
#172 PostAuthor: ted1r » Fri Jan 09, 2009 6:28 pm
Got ot hand it to you Mr P you have done a good job with that.now start saving for your longjohns for the Yorks rally :lol:
Well done.
Regards Ted
#173 PostAuthor: paul doran » Fri Jan 09, 2009 11:53 pm
wait till he gets to finishing it
anyone know when CMM are giving away more spanner's :lol: :lol: :lol:
#174 PostAuthor: Pigford » Sat Feb 07, 2009 5:45 pm
Right then..... had a spare few hours to have a bit of a fiddle with the bike :shock:
Its still a PIG to start........... :cry: Battery is well charged..... but just turns & turns... :??
So, decided to fit the Dyna S :P Checked voltage to coils.... only 1 volt less than at battery..... so I assume thats OK :?:
Before when it was eventually running, would "hang-up" on revs..... :!: Now this was NOT due to sticking slide or tight throttle cables :shock:
It was on 145 mains & 25 pilots... & tried fuel (like air) screw out from 1/2 a turn to 2 turns... :| Float height 18mm :wink:
So decided to change pilots & mains... Carbs off :??
Fitted 30 pilots & 155 mains....... She did start but still took some time :!:
As you may well have noticed shes running a bit rich..... but sounding a bit smoother..... :D
tlc
#175 PostAuthor: tlc » Sat Feb 07, 2009 6:04 pm
Crikey Mark. There`s as much coming outta the carbs as there is out the zorst :!:
Starts alright though don`t it :D
#176 PostAuthor: Pigford » Sat Feb 07, 2009 6:07 pm
B*****d only starts OK once warm... :??
She still "hangs up" on the revs tho :evil:
Could be coz too rich.... all that excess fuel making it rev :?:
But its such a sod to start up :?: Fuel is getting thru & spark seems good :|
The carbs blow back is coz of the lumpy cams :wink: I haven't degreed them in yet, just set them up as they were :shock:
tlc
#177 PostAuthor: tlc » Sat Feb 07, 2009 6:20 pm
No probs. Just stick it on the centrestand and kick it over :D
#178 PostAuthor: Ginger Bear » Sat Feb 07, 2009 7:04 pm
Piggy,
1 volt less at the coils is quite a bit. Get yourself down to Maplins & do the relay mod. Everything to gain for a fiver or so. I have it in my head (read it somewhere) that while spark looks ok, once under compression it is weaker. Could explain poor starting :?:
Oh yeah......... Your bum does look big in those overalls :hys
steve.w
#179 PostAuthor: steve.w » Sat Feb 07, 2009 8:49 pm
could be valve clearences but it sounds like the carbs are goosed
#180 PostAuthor: Al » Sat Feb 07, 2009 8:55 pm
Mark i think the photobucket link has gone on the fritz. I only get a black screen or is that what you meant about it running rich?
Edit; it says the file size is 1Kb if that helps!
