z1a front caliper
mick znone
z1a front caliper
#1 PostAuthor: mick znone » Thu Jan 22, 2009 9:45 am
OK guys, any clues :?: front brake caliper z1a. in the zpower parts book and Haynes book ref.no7[ bush rubber x1], the zpower repair kit doesn't have one, Haynes doesn't explain where it goes, clymer says use a Kawasaki dealer[helpful that]. any tips gratefully received. brake rattled last summer, want to avoid rattle this summer, if possible.
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Thu Jan 22, 2009 10:21 am
Mick.
The rubber bush you are refering to is available from Z-power as a seperate part and is held in place by a round ring on the leading edge of the caliper bore,its a dust seal.The round ring is a tight push fit into the bore,don't think this is available though.
The rattle will be cured by fitting 2 new 0 rings to each caliper shaft and coating each shaft with copper slip grease thus allowing the caliper to "float" on the shafts.
Regards
Steve
