URGENT 530, 18 tooth, 13 spline, 15mm offset, front sprocket
Gus
#1 PostAuthor: Gus » Fri Feb 13, 2009 9:47 am
Hi.
Does anybody have a "530, 18 tooth, 13 spline, 15mm(5/8 inch) offset," front sprocket to fit the Z1, Z1A, Z1B, Z900, Z1000A1/4, H, and Z1R that I could borrow to set my chain alignment on my project.
I am waiting for Debben to recieve a new batch from their suppliers but that is 4 or 5 weeks away.
This is major hold up time.
"Set the GRINDER on it"
Keefleaf
#2 PostAuthor: Keefleaf » Sun Feb 15, 2009 3:56 pm
I think Gpz 750 turbo drive sprockets do the job,but check.
Gus
#3 PostAuthor: Gus » Sun Feb 15, 2009 4:24 pm
Hi Keefleaf.
I had a look on the JT sprockets website and the GPZ 750 Unitrack has the correct fitment and an offset but not enough.
I need 15mm of offset and then the thickness of the sprocket on top of that.
I'll keep trying.
