Original 73 Coils - Can I replace the HT leads?
#16 PostAuthor: Pigford » Fri Feb 13, 2009 5:49 pm
As Garn1 says be careful when tightening the LT terminals as the screws are quite small and the threads soft
Its not the screw thread insert stripping, its the plastic body of the coils thats like 'soap' :roll: The inserts tend to 'spin' in the coil body.... but I had a set (2nd hand) that did this, but they worked OK :??
