project Z1A FINISHES
bunnysZ
Granny Magnet
#16 PostAuthor: bunnysZ » Wed Sep 10, 2008 7:21 pm
engine is good, will clean it myself with a toothbrush and solvent during the winter.
front forks/wheel etc off now , just need to remove coils electrics battery box and engine now .
GUYZED
#17 PostAuthor: GUYZED » Wed Sep 10, 2008 9:12 pm
Paul - wouldn't it have been easier to get the engine out before you removed the front end :?:
That's the way i would have done it. :D
#449
Z1000A2 Z650B1
RALPHARAMA
#18 PostAuthor: RALPHARAMA » Thu Sep 11, 2008 7:08 am
I always remove engines your way Guy, but there is a school of thought where the engine and frame is laid on it's side and the frame lifted on / off the engine. Many folk swear by this method and maybe I'll try it next time. The logic goes that the frame is much lighter than the engine and you're less likely to do damage to the paint on the frame that way. Not tried it myself.
Ralph Ferrand
Steve R
#19 PostAuthor: Steve R » Thu Sep 11, 2008 8:08 am
I allways remove the engine by stripping it down to a frame and engine then laying it on its side, on an old foam settee cushion and lifting the frame off . Its much easier to lift the frame as its so much lighter and you are much less likely to damge your paint or your back and it makes it an easy one man job.
When putting it back in it helps to remove the cam cover just to get that litle extra bit of clearance and rap the exhaust dtuds in some tape to stop them scratching the frame.
#20 PostAuthor: chrisu » Thu Sep 11, 2008 8:14 am
agreed. if you're doing a full strip down much the easiest way to do it.......
bunnysZ
Granny Magnet
#21 PostAuthor: bunnysZ » Thu Sep 11, 2008 5:37 pm
engine out no problem , bike on its side and frame slipped off as previosly mentioned. didnt mine scratching it a bit getting it out , but looks a difficult job when putting it back, :??
Steve R
#22 PostAuthor: Steve R » Thu Sep 11, 2008 6:05 pm
Wnt be a problem, leace cam cover off tape over exhaust studs chock engine up with some timber and take your time manoevering it over. No problem :fire
DogsbolloxofZ1B
#23 PostAuthor: DogsbolloxofZ1B » Fri Sep 12, 2008 8:53 am
Bunnyz,
If you need a hand putting the engine back give me a call. Best to remove the exhaust studs if you can but not absolutely necessary.
:P
Mike
bunnysZ
Granny Magnet
#24 PostAuthor: bunnysZ » Tue Feb 17, 2009 5:35 pm
like steven cooke i have also been working on my project over the winter
months, (sadly not to the same standard)
stripped bike down , got the engine out by tipping it on its side no problems there. sent frame and other parts to powder coaters polished all the nuts and bolts up clocks refurbished , and swapped tank set with hutch.
dogbollox came around the other day and engine went in as easy as it came out :D cheers mike . bolting bits and pieces back on now so slowly but surely getting there.
#25 PostAuthor: chrisu » Tue Feb 17, 2009 5:44 pm
let me know when you want to do the shims.....
tlc
#26 PostAuthor: tlc » Tue Feb 17, 2009 5:47 pm
Nice Z1 placemats there Paul :D
#27 PostAuthor: Ginger Bear » Thu Feb 19, 2009 8:23 am
That engine does look clean :!: Bet your teeth don't look so good now though :!: :cl :cl
bunnysZ
Granny Magnet
#28 PostAuthor: bunnysZ » Tue Feb 24, 2009 7:52 pm
latest update , thanks to chrisu and tlc at the weekend
#29 PostAuthor: Ginger Bear » Tue Feb 24, 2009 8:09 pm
Just scrolled back through this thread & looked at the paintset again.
That's gonna be a'Stunning' bike!
PaulMceleney
Chunks
#30 PostAuthor: PaulMceleney » Tue Feb 24, 2009 8:10 pm
you done a good job on the engine paul how long did you spend on it, did you only use autosol
