alloy cleaner
colinw
alloy cleaner
hi guys, what is the best alloy cleaner to use or are there any homemade potions that can be used.many thanks
Russ
Cleaners
Depends wot your cleaning really. If your just trying to clean the engine fins and all and you have the motor stripped there is no real substitute for vapor blasting. There are many concoctions out there for alloy wheel cleaning which all contain an acid base and I have tried several and in all cases I have found the results dissapointing. Just make a streaky mess. Jizer or gunk are a good bet for degreasing as a first stage clean and I have had good results from just hard work with nylon kitchen scourers and solvol autosol. For polishing cases I have had good results just by using 400 and 600 wet and dry and finishing with solvol autosol. All time consuming hard work though I'm afraid. Hope this has been some help.
Hi Colin,
I use solvol but another good polish that i use is BELGOM ALU. It leaves a protective wax film ( invisiable) on the covers (clutch, points, alternator etc). though as russ said if its the barrels, head and crankcase then vapour blasting is really the only way off getting into the places you cant get with your fingers.
- london calling
colinw
alloy cleaner
many thanks for the replies about alloy cleaners.i have used gunk to degrease first then given a good wipe round with sugar soap as this has fetched even more crud off.not tried cillit bang yet although i did use it on some stainless steel piping that had hard water marks on and it worked a treat!!! have given a polish with solvol autosol and am happy with the finish.many thanks again.
colin
colin
dave3d
cillit banger
HI, Did you ever try the Cillit bang method? Sounds pretty easy, my whole engine is filthy - and the cases need polishing.
polish
according to MCN peek is better than auto solvol they did a test for the paper to find the best.
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
sparky650
dave3d
Users browsing this forum: Kwackman and 71 guests
