cockpit fairing
Redbeard
cockpit fairing
#1 PostAuthor: Redbeard » Tue Mar 17, 2009 8:03 pm
Considering something like this for my ST, anyone know if they fit z's without much alteration? If not, can anyone point me in the direction of something similar? Cheers all.
http://www.mandp.co.uk/productInfo.aspx?catRef=517880
1979 Z1000ST
#2 PostAuthor: Al » Tue Mar 17, 2009 8:35 pm
I put one on my J1 because i liked the look of them and i couldnt see my clocks and indicator repeater in bright sunlight.
Made four strip ali brackets. drilled four holes. Replicated brackets in 2mm mild steel. Havent touched it since.
On the down side; it make my front end oscillate in blustery conditions and the 'ramp' of the screen focuses the airflow directly into my chin and neck area.
Redbeard
#3 PostAuthor: Redbeard » Tue Mar 17, 2009 8:46 pm
Thanks zorded, very useful info. I'll let you know how I get on with it. Cheers!
1979 Z1000ST
Dark Skies
#4 PostAuthor: Dark Skies » Tue Mar 17, 2009 9:40 pm
I had one of these on my Z1000 H.
A good bit more money but absolutely stable at !00 + speeds. Good headlights too. I mounted it to some alloy headlamp brackets and at the bottom where the front brake splitter connects to the lower fork yolk.
http://www.skidmarx.co.uk/section/fairi ... ckpit.html
KZ1000-M1 CSR
Redbeard
#5 PostAuthor: Redbeard » Tue Mar 17, 2009 9:47 pm
cheers, one on ebay but wrong colour. worth spending more if its stable at speed. thanks!
1979 Z1000ST
