ignition question
bakey
ignition question
#1 PostAuthor: bakey » Wed Mar 25, 2009 3:57 pm
Right lads
the ignition is a bit dodgy on my bike...by dodgy i mean you can take the key out while the engine is running! I noticed the other day when i was riding it and the key nearly fell out.
anyway, it looks like ill be replacing it but what i dont really want is a handfull of different keys. Currently 1 key does ignition, tank and seat and another for the steering lock. Will tells me this is correct though?
anyway, is there anyway you can make a new ignition barrel take a different key? anyone done this or maybe someone is a part-time locksmith?
''Who's motorcycle is this?''
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Wed Mar 25, 2009 5:27 pm
bakey
Take a run over to Toxteth there will be someone there who can sort you out!!!
mick znone
#3 PostAuthor: mick znone » Wed Mar 25, 2009 7:41 pm
i believe you can buy lock sets Bakey, maybe the great zpower could help.
Davy Doherty
#4 PostAuthor: Davy Doherty » Wed Mar 25, 2009 9:21 pm
It should be one key for the lot so something's wrong
#5 PostAuthor: Ginger Bear » Wed Mar 25, 2009 10:54 pm
Bakey,
Any key will open the fuel cap, so if you bought a new ignition, at least the key would fit that, just seperate for steering lock & seat lock. :|
mick znone
#6 PostAuthor: mick znone » Thu Mar 26, 2009 7:41 am
i believe its always been a different key for the steering lock.
steve bowdler
#7 PostAuthor: steve bowdler » Thu Mar 26, 2009 9:31 am
Bakey I had the same trouble but actually lost mine while travelling home from the bucks rally bought a new key, number stamped on barrel if I remember correctly and now new key stays in ignition and have'nt changed all locks etc ..
tlc
#8 PostAuthor: tlc » Thu Mar 26, 2009 10:16 am
mick z1a wrote:i believe its always been a different key for the steering lock.
One key fits all on mine.
That`s how it left the factory.
Kev1R
#9 PostAuthor: Kev1R » Thu Mar 26, 2009 10:41 am
I was thinking of buying new ignition switch from Z Power (for Z1R)
I believe any key fits petrol tank, seat lock & helmet hook?
But I had not thought about the steering lock –
Does this mean I would still need the old key for the steering lock?
bakey
#10 PostAuthor: bakey » Thu Mar 26, 2009 3:34 pm
lads would a Z1B ignition work in my bike? dont know squat about the amount of pins/connectors etc
can anyone confirm the steering lock question? will has assured me that steering locks are always a different key...obviously people on here under that assumption. Not that i doubt your rivetting counting skills though chris :D
mick znone
#11 PostAuthor: mick znone » Thu Mar 26, 2009 5:40 pm
now then, ive just seen a set of locks with key for the z900, it seems the steering lock uses the same key, i thought otherwise, i will look for the set again and report back.
mick znone
#12 PostAuthor: mick znone » Thu Mar 26, 2009 5:45 pm
there's a set here, johnnys vintage motorcycles, i cant seem to do a link, if you google it they have an ebay shop, you will find one in the z1 section bakey, it looks like the steering lock comes with it, so is the same key.
#13 PostAuthor: Rich » Thu Mar 26, 2009 6:52 pm
"anyway, is there anyway you can make a new ignition barrel take a different key?"
Yes you will need to carefully bend the retainers out on the casing and they go through the back to release the tumblers which are held in be a sprung catch. Having the correct key in helps to align the tumblers for removal. file /swap the tumblers around for the new key. Remember how it comes to bits and don't lose the small springs
bakey
#14 PostAuthor: bakey » Thu Mar 26, 2009 7:09 pm
right lads, 794 on my steering lock and 794 on the key for it only works that lock.
the ignition key is a copy anyway - got SILCA written on it and also number 759 although that might be complete fluke. fits everything but the steering lock. No numbers on ignition barrel and i cant see any numbers on seat lock either.
might be looking at 3 keys here which is crap tbh
spoke to TLC and he started talking about key numbers for the models :shock: so does anyone on here know what keys match either my model or for more respect...who knows the full number compatability for the zed range :?:
Davy Doherty
#15 PostAuthor: Davy Doherty » Thu Mar 26, 2009 7:09 pm
Definatly one key for everything period... and yes a Z1B ignition switch will work.
