Points & condensers
Points & condensers
#1 PostAuthor: Pigford » Sun Mar 29, 2009 7:58 pm
Sorry, but not for the Zed.... its me Trumpet :oops:
Nearly finished the wiring on the old girl, but need help with the points :!:
My set up has 'remote' condensers, which means the condensers are normally located under the fuel tank. As my bike is far from standard & I have had to rewire it, the last thing is to get the timing sorted.
I have a wire coming from each set of points (+ positive), which will feed one of the low tension connections on each of the coils. Am I right in assuming all I need to do is connect a condenser to this points feed :?:
Users browsing this forum: No registered users and 91 guests
