High speed/revs splutter
mikey
#1 PostAuthor: mikey » Thu Apr 02, 2009 6:07 am
All of a sudden my Z1000 has developed this problem, when i accelerate hard and the revs climb above 4,000 it splutters/misfires quite badly but it dosent do it all the time any ideas anybody?
Steve S
#2 PostAuthor: Steve S » Thu Apr 02, 2009 1:09 pm
Could be coils breaking down :?: check leads,plug caps etc for condition and security. :idea:
bigmac103
#3 PostAuthor: bigmac103 » Thu Apr 02, 2009 2:38 pm
I had the number 2 spark plug causing this kind of problem too. It would misfire at 5k rpm. Changed plug and problem went away!
Lost in the desert somewhere
mikey
#4 PostAuthor: mikey » Thu Apr 02, 2009 6:19 pm
Steve got dyna s coils on it and brand new leads plug caps and plugs, bigmac put old plugs in and its just the same, however in saying that been out on it today and its been alright, could it be as maralyn suggested to me today bit of crap floating round in the carbs and now and again it floats up and blocks the jets?
bigmac103
#5 PostAuthor: bigmac103 » Thu Apr 02, 2009 6:26 pm
Have you dropped the carb bowls and had a look? Is there a kink in one of the fuel lines? One more thing, does it feel like you're running out of fuel when it happens?
mikey
#6 PostAuthor: mikey » Thu Apr 02, 2009 6:45 pm
No not yet planning to have a look at the weekend but yes it does feel like its running out of fuel when it happens.
bigmac103
#7 PostAuthor: bigmac103 » Thu Apr 02, 2009 7:00 pm
Then I would check the fuel chain. Sounds like a restriction, so carbs are looking like the cause? Definitely worth looking in the bowls. If you can take a picture of what you find would be good.
mikey
#8 PostAuthor: mikey » Thu Apr 02, 2009 7:36 pm
Ok cheers mate have a look the weekend let you know what i find.
#9 PostAuthor: Rich » Thu Apr 02, 2009 7:55 pm
Try opening the petrol cap when it does it to see if it improves, maybe breather blocked.
mikey
#10 PostAuthor: mikey » Thu Apr 02, 2009 8:44 pm
Ok cheers rich thanks for the tip.
mick znone
#11 PostAuthor: mick znone » Thu Apr 02, 2009 9:34 pm
now Mikey, no getting up in the night, look at it in the morning mate :)
mikey
#12 PostAuthor: mikey » Thu Apr 02, 2009 9:59 pm
You know me to well already mick :D
mikey
#13 PostAuthor: mikey » Fri Apr 03, 2009 6:06 am
Rich wrote:Try opening the petrol cap when it does it to see if it improves, maybe breather blocked.
Now and again i can hear a hissing noise from the fuel cap when i open it it stops almost like there is pressure building in the tank, i just had the fuel cap re chromed but i took it apart to have it done, could i have put it back together wrong and blocked the breather hole.
#14 PostAuthor: chrisu » Fri Apr 03, 2009 6:38 am
certainly sounds like it.......
mikey
#15 PostAuthor: mikey » Fri Apr 03, 2009 7:09 am
Ok cheers chris i will check that as well.
Users browsing this forum: No registered users and 76 guests
