Helicoil - Large threads
The spindle thread in the USD forks on me Zed (female thread) is a bit naff.... Its a 20mm thread.... Can you get helicoils to repair these
Steve Cooke
- ZedHead
Mark Uni-Thread do 20mm but you need the set to do it, as in tapping drill, tap,insert and insertion tool, depending on the pitch their prices for a boxed kit are 2.5mm pitch = £58.25
2.0mm pitch = £61.50
1.5mm pitch = £67.50
if you just have the drill,tap and insert they're about a tenner less, you could also try Tracy Tools 01803 328603 I think they are linked with Uni-Thread in some way but for some items they can be a bit cheaper.
