Maintenance Free Battery
#16 PostAuthor: Pigford » Wed Apr 01, 2009 9:25 pm
I got mine off eBay.... new, still boxed for £68 delivered... Private sale, no longer needed :wink:
I think they need a decent 14v charge, so all it means is the bikes system must be in GOOD WORKING ORDER, so not too LITTLE volts, nor TOO MUCH :!:
Google Odyssey & it theres a few suppliers in the UK... ones called Robots or sumink :??
mick znone
#17 PostAuthor: mick znone » Wed Apr 01, 2009 9:30 pm
OK, £93 and last 3 times as long as conventional batts. better cranking and easy care. :)
mick znone
#18 PostAuthor: mick znone » Fri Apr 03, 2009 9:43 am
could someone help me guys, as I'm away from home for a bit. i need to know the size dimensions for the battery on the z1a, :?: :?:
#19 PostAuthor: Pigford » Fri Apr 03, 2009 7:23 pm
Mick, I would help if I could..... but I don't have a std battery arrangement :cry:
Try & google it, coz I'm sure I've seen details somewhere :?:
Skunkwurcx
#20 PostAuthor: Skunkwurcx » Sun Apr 05, 2009 1:19 pm
Battery is in as of a few mins ago...same size as the stock unit(or the replacement that was in it) . Defo spins the engine over faster than the old one did even when fully charged.
It's cold and wet here today, so unless that changes, it won't be going for a run today :(
RALPHARAMA
#21 PostAuthor: RALPHARAMA » Mon Apr 06, 2009 9:58 pm
I stuck a fairly cheap gel in my Zed and it seems absolutely fine. I am trade so I got it pretty cheap and thought it worth the gamble. Since I restored my bike I have new windings, modern reg/rec and I built a new loom so it has to be said that my wiring is tickety boo. I have no idea how long it will last, but so far so good. It was certainly cheaper than a conventional Yuasa.
Ralph Ferrand
