Barrel Removal
Barrel Removal
#1 PostAuthor: PAULJAC47 » Mon Apr 06, 2009 8:11 pm
Hi All Any tips on removing barrels without resorting to the rubber hammer technique with its danger of fin damage?
#2 PostAuthor: Pigford » Mon Apr 06, 2009 8:26 pm
Rubber mallet is quite safe - due with care :wink:
Wedge some wood on front under cam chain tunnel bit & wallop with a f*ckoff large implement :??
Some barrel have small cutouts each side to carefully insert a flat bladed screwdriver for gentle persuasion :twisted:
Tie rope around barrels, tie up over frame. tie a rope loop to each side of rope (from left to right) & put lever in & twist... this will cause barrels to lift (hopefully) along with gentle rubber persuasion :!:
#3 PostAuthor: PAULJAC47 » Mon Apr 06, 2009 8:41 pm
Cheers Mark!!!!!!!
#4 PostAuthor: Rich » Tue Apr 07, 2009 7:13 am
prise them off with a screwdriver in the slots at the bottom of the barrel
GEZ635
#5 PostAuthor: GEZ635 » Wed Apr 08, 2009 2:59 pm
can send you a picture of a tool we copied from a genuine kawasaki tool that costs about £3 and takes 5 mins to make out of some half inch square bar. Always works even on barrels that have never been off and there is no risk of any fin damage or damaging the gasket face with a screwdriver. We got the bar from b and q, drilled one hole in it, a small recess and you are ready to lever away. Its the best way we have ever tried to get barrels off with no effort. Let me know if you want a picture of it and how it fits. Gez
Gez
Garn 1
#6 PostAuthor: Garn 1 » Thu Apr 09, 2009 1:01 am
Gez635, It would appreciated, if you would post a picture of that Kawasaki barrel removal tool, on this thread. I have seen a home-made version that pushes, by means of four threaded rods, on the four pistons.
GEZ635
#7 PostAuthor: GEZ635 » Thu Apr 09, 2009 11:09 am
Garn, send me an email address.
Gez
#8 PostAuthor: PAULJAC47 » Thu Apr 09, 2009 5:02 pm
Just made up this tool as Rec by Geza using a piece of old torsion bar it took me 5 mins to make, tried it for size on bike and thought would give it a go,barrels popped straight up,job done 15 mins.....Top Tip Gez!!!!!!!!!!!!!!!! :) :D :D
tlc
#9 PostAuthor: tlc » Thu Apr 09, 2009 5:07 pm
Show us all the picture will yer ?
Torsion bars are my stock in trade !
GEZ635
#10 PostAuthor: GEZ635 » Fri Apr 10, 2009 5:52 pm
Glad you found it helpfull, and how easy is it too make!!! Will post a picture tomorrow as it may help a few others. Gez
Gez
Users browsing this forum: No registered users and 76 guests
