twin headlights - for HowieD
#1 PostAuthor: chrisu » Mon Apr 13, 2009 8:14 pm
Let me know if you want more photos. These were hung off a bracket bolted to the top clamp/headstock.
Bates style headlights with cibie headlamps. Now off the bike as I've gone back to a single headlight..... [/img]
HowieD
#2 PostAuthor: HowieD » Wed Apr 15, 2009 12:06 pm
Thanks Chrisu.
Have you got a pic from the side or a close up of the bracket?
I have an idea to make something similar.
I used to have 2 monster Cibie Oscars once but it might look better with 6" jobbies like this instead.
Regards
Hx
#3 PostAuthor: chrisu » Wed Apr 15, 2009 3:55 pm
sorry but the bracket also held the clocks - I had to cut off the bit where the headlamps bolted onto so phot won't be a lot of use to you. I didn't make up a complete new clock bracket - lazy I know..
was just two steel plates (with a hole bored through each plate) that the lump of ally slotted between and was bolted up to (if that makes sense)
HowieD
#4 PostAuthor: HowieD » Thu Apr 16, 2009 8:56 am
Hello,
Thats great and such a simple solution.
thanks for posting the pics..
Hx
Users browsing this forum: No registered users and 117 guests
