Possible Carb Problem
bollypne
#1 PostAuthor: bollypne » Mon Apr 20, 2009 8:20 am
Hi all, I've had my carbs off that many times i think i can do it with eyes shut, almost.
Seems the bike is running ok ish, ticks over nicely, best since i got it. Goes like stink when opened up, quite a suprise really, I had a 1200 bandit before the Z, so i was well made up. Enough, i degress. So at speed she seems to run well.
Starting is one area of concern, fires up easy enough but it is misfiring, choke on briefly. Misfire is gone when revved a bit, wont idle on choke but soons settles when warm.
Also, after she is warmed and run a few miles, tickover is fine but opening the throttle slightly/slowly results in roughness, a harder throtlle blip goes through with little/no roughness?
Checking the plugs after a good run shows no1 plug to be very clean, possibly weak, the other 3 show sootyness.
Carbs have all new jets, needle and gaskets. Full kit.
Also yesterday, towards the end of quite a hard run, probably 80ish for about 30mils(A50 from Derby to Stoke). Engine cut out at about 70 for 3seconds and then ran again! I did not catch the cut off switch.
Any thoughts/advice would be good.
Colm
Big Bol
Z900, ZRX1200r & a Z900rs Cafe
bollypne
#2 PostAuthor: bollypne » Mon Apr 20, 2009 8:39 am
In addition to replacing the carb jets etc i also checked valve clearances. Some needed adjusting. I was a bit worried about chacking adjusting the valves as i had never tocuhed shims before. Easy.
Big Bol
bigmac103
#3 PostAuthor: bigmac103 » Mon Apr 20, 2009 10:19 am
Hi Colm,
My A4 won't Idle 'till it's warm. I had problems similar to you, turned out just to be a dodgy plug. I also changed the wiring to give more voltage at the coils. Chrisu gave me this link and it worked a treat.
http://www.wgcarbs.com/index.php?option ... &Itemid=26
Plus I think you should sort out the valves first and start a process of elimination.
B
Lost in the desert somewhere
bollypne
#4 PostAuthor: bollypne » Mon Apr 20, 2009 11:23 am
Hi, valve clearances are now all good and still same issue. Also changed plugs to Denso. Will check the link, Thanks.
Colm
Big Bol
#5 PostAuthor: Rich » Mon Apr 20, 2009 5:48 pm
Check for loose connections, springs in the kill switch, ignition switch broken wires - 80 ish for thirty miles is normal use.
Check and adjust the fuel heights then synchronise.
bollypne
#6 PostAuthor: bollypne » Tue Apr 21, 2009 7:02 am
Rich wrote: Engine cut out at about 70 for 3seconds and then ran again!
Cheers Rich, new switches fitted a little while back. So off with the carbs again. Smashin, though it is easy.
Big Bol
DogsbolloxofZ1B
#7 PostAuthor: DogsbolloxofZ1B » Tue Apr 21, 2009 3:41 pm
Did you change the needle jets along with the needles? These need to be a matched pair! Occassionally you'll get away with replacing just the needle but often you'll have mixture problems i.e. can't dial the mixture in with the airscrew.
My 2cents. :wink:
#8 PostAuthor: chrisu » Tue Apr 21, 2009 4:41 pm
carbs balanced ??? - mine were WAY out after fitting new carb kits !
Crap in the fuel filter - you do have one don't you ......... ????
bollypne
#9 PostAuthor: bollypne » Wed Apr 22, 2009 7:03 am
New needles fitted with needle jets. Not sure how to 'dial the mixture in' with the airscrew.
Will be checking carb balance again this weekend.
thanks
Big Bol
Steve S
#10 PostAuthor: Steve S » Wed Apr 22, 2009 8:52 am
This may help.........Turn in the air screw of each carb fully but not tightly and then back it out 1 1/4 turns,start engine and warm up, adjust idle to about 800-1000 rpm.
Adjust each air screw 1 at a time,first turning in one direction and then the other until the highest idle is determined,if the idle rises too much adjust accordinly using the main idle adjusting screw.Note: if any any carb air screw can be turned in to less than 1/2 turn from full in,without idle change there is probably trouble with that carb(ie pilot jet/blockage etc).
Once highest idle is set turn all air screws in equally a small amount,readjust idle and check with vacuum gauges if needed. :D
Hope this helps good luck.
bollypne
#11 PostAuthor: bollypne » Wed Apr 22, 2009 10:54 am
Steve S wrote:This may help.........Turn in the air screw of each carb fully but not tightly and then back it out 1 1/4 turns,start engine and warm up, adjust idle to about 800-1000 rpm.
Cheers, will give it a go, love messing.
Big Bol
KeithZ1R
Re: Possible Carb Problem
#12 PostAuthor: KeithZ1R » Wed Apr 22, 2009 8:36 pm
Colm
three seconds is a long time I would go with Rich cut out swith has bounced
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
bollypne
#13 PostAuthor: bollypne » Wed Apr 22, 2009 8:51 pm
Colm
cheers Keith, new switches fitted recently. Will be checking all connections over the weekend.
Big Bol
