Another Chain n Sprocket Question
bigmac103
#1 PostAuthor: bigmac103 » Sun May 10, 2009 1:25 pm
Can you use the same chain for the 35 and 33 tooth rear sprocket?
Thankz
B
Lost in the desert somewhere
compo z1r
Re: Another Chain n Sprocket Question
#2 PostAuthor: compo z1r » Sun May 10, 2009 3:38 pm
bigmac103 wrote:Can you use the same chain for the 35 and 33 tooth rear sprocket?
Thankz
B
yes if its the same pitch. :roll:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
#3 PostAuthor: Pigford » Sun May 10, 2009 5:13 pm
Bigmac.... as long as you keep to the same format - ie: 630 or 530 ..etc.
If you're replacing an old knackered sprox with a new one, then there may be rapid wear on the new sprox, as the cahin set wears/stretches with use :shock:
Garn 1
#4 PostAuthor: Garn 1 » Sun May 10, 2009 8:35 pm
Guys, I think BigMac is concerned about the length of the 630 chain. That is, will the 33 sprocket with 2 less teeth still fit in the adjustment range of the usual 92 link chain? Or, will he have to remove a link? I not sure of the answer I think it both sprocket would serve the one chain length.... Could be wrong!
floydsz1
#5 PostAuthor: floydsz1 » Sun May 10, 2009 8:55 pm
I have fitted z900A4 rear sprox to a Z1 ie a smaller rear to lower revs for better cruising etc without having to remove a link, unless the chain is very worn and stretched.
