Can you use the same chain for the 35 and 33 tooth rear sprocket?
Thankz
B
Another Chain n Sprocket Question
Lost in the desert somewhere
Re: Another Chain n Sprocket Question
bigmac103 wrote:Can you use the same chain for the 35 and 33 tooth rear sprocket?
Thankz
B
yes if its the same pitch.
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Guys, I think BigMac is concerned about the length of the 630 chain. That is, will the 33 sprocket with 2 less teeth still fit in the adjustment range of the usual 92 link chain? Or, will he have to remove a link? I not sure of the answer I think it both sprocket would serve the one chain length.... Could be wrong!
