Z1000ST Mudguard
paulstrees
Z1000ST Mudguard
#1 PostAuthor: paulstrees » Tue May 12, 2009 7:29 pm
Anyone got an ST mudguard or mark 2 or I believe a Z1r will fit
Paul
outlaw
#2 PostAuthor: outlaw » Wed May 13, 2009 5:54 pm
have a look at a z750 1981 model they seem very close to what the st one looks like.
john
ollie
#3 PostAuthor: ollie » Wed May 13, 2009 11:31 pm
are we talking front or rear paul, i have a uk rear plus inner for an st if your interested
:wink:
#4 PostAuthor: paul doran » Thu May 14, 2009 10:19 am
MK2 are different
Iain marshall
#5 PostAuthor: Iain marshall » Thu May 14, 2009 5:35 pm
As Paul says the mudguards are different,the ST has a leading axle which causes the guard to sit further forward and if i remember right the space between the forks is wider on the ST.Hope this is of some help
outlaw
#6 PostAuthor: outlaw » Thu May 14, 2009 5:36 pm
hi, paul what is the different between the mark 1/2 as the photo of the rear looks the same,
thanks john
Iain marshall
#7 PostAuthor: Iain marshall » Thu May 14, 2009 5:45 pm
John thats the problem, they do the similar.One the MKII the mounting holes are symetrical ie the mudguard could be fitted either way round.On the ST the mounting holes are further back due to the axle being at the front of the fork leg.
outlaw
rear
#8 PostAuthor: outlaw » Thu May 14, 2009 6:35 pm
thank you, but i did not make myself clear i ment the REAR MUDGUARD :oops: as mine is missing and i have chance of getting one,
john
#9 PostAuthor: paul doran » Fri May 15, 2009 8:28 pm
the rear is plastic and should fit either
