Back to the drawing board
mikey
#1 PostAuthor: mikey » Wed May 20, 2009 8:51 am
Well took it out this morning and for about quater mile all was well then it all started again misfiring, spluttering, and now something new backfiring just turned round went home and pushed it in the garage, guess yorkies off the to do list this year. :cry:
steve f
#2 PostAuthor: steve f » Wed May 20, 2009 11:08 am
sounds electrical to me
zedrider
#3 PostAuthor: zedrider » Wed May 20, 2009 1:27 pm
if i had to guess going by what you have told me maybe a coil going south . does she die all together or feel like shes on two by any chance ? if not that check the tap filter bowl . might be filled with yuck not allowing the free flow of fuel .
zed
Mick Hayward
#4 PostAuthor: Mick Hayward » Wed May 20, 2009 3:01 pm
Mikey
Try the WD40 on the rubbers again. My ST was okay untill it got warm. You'll just have to keep trying untill you find the problem. Just resit the temptation to start changing things. Its expensive and rarely gives good results.
Z.O.A
#5 PostAuthor: Z.O.A » Wed May 20, 2009 3:14 pm
steve f wrote:sounds electrical to me
I agree, because it's intermittant I reckon you may have some arcing from a live somewhere in the ignition wiring or from the coils/leads/caps, especially when you mentioned the little jolt in the rain. I know your head must be wrecked with it at this stage, I really hope you do get it sorted soon, just take all hammers and blunt objects out of the garage before going at it again :wink: :wink:
tlc
#6 PostAuthor: tlc » Wed May 20, 2009 3:55 pm
If it`s giving you a belt then it must be HT not LT.
Coils, leads, caps. Tank off........spray with water and see what happens.
hillbilly
#7 PostAuthor: hillbilly » Wed May 20, 2009 4:35 pm
try running it with tank off ,but in the dark.pitch black,then check for the ht leads for tracking. :?:
mick znone
#8 PostAuthor: mick znone » Wed May 20, 2009 5:17 pm
leave it alone, get off your head, play loud energetic music, followed by melancholic music, cry a bit, pass out, come to, then try the above suggestions, :star
Taffus
#9 PostAuthor: Taffus » Wed May 20, 2009 5:26 pm
mick z1a wrote:leave it alone, get off your head, play loud energetic music, followed by melancholic music, cry a bit, pass out, come to, then try the above suggestions, :star
Or ask Ralph for some help, go on you know it makes sense :D
z900dave
Re: Back to the drawing board
#10 PostAuthor: z900dave » Wed May 20, 2009 5:36 pm
I had a similar sounding thing on mine. the problem turned out to be a coil that started to play up once warm. The backfiring was due to a build up of fuel when the coil wasn't firing which ignited. I changed the coil problem solved. Hope this is of some help and you get sorted.Dave :lol:
mikey wrote:Well took it out this morning and for about quater mile all was well then it all started again misfiring, spluttering, and now something new backfiring just turned round went home and pushed it in the garage, guess yorkies off the to do list this year. :cry:
Z900Dave
bunnysZ
Granny Magnet
#11 PostAuthor: bunnysZ » Wed May 20, 2009 5:55 pm
mikey
I have 2 good coils and leads you can borrow if you want, elimnate that prob, and if needed keep until you get new ones .pm me youre add,
#12 PostAuthor: Rich » Wed May 20, 2009 6:07 pm
Is that 1/4 mile actually 1/4 mile?
Did you warm it up before setting off?
When did you turn the choke off?
#13 PostAuthor: Pigford » Wed May 20, 2009 7:27 pm
As I said before... sounds electix to me... dodgy coil most probs... or connection :!:
mikey
#14 PostAuthor: mikey » Wed May 20, 2009 8:19 pm
Tried another set of coils today and were alright for a while but its gone again realy dont know what else to do
Padders
#15 PostAuthor: Padders » Wed May 20, 2009 8:39 pm
Are you running points Mikey if so it maybe one of the condensors is breaking down under load.
