Back to the drawing board
- big green bus
MIKIE
MIKEY
Had similar problem myself i know you have cleaned carbs but like yours mine ran for a while then shite when the jets blocked up switched it of then the shit dropped from the jets . Started it up again ok at first then again sucked shite up in jets ran shit . I know youve proberbly cleaned carbs umptine time but just an input .
Phil
PS RALLY WONT BE SAME WITHOUT YA GET THE TRUMPET OUT
Phil
International Rep
International Rep
Mikey,
I have an ultrasonic cleaner..... will only do one carb at a time, but they need to be completely stripped anyway.
If you strip 'em, I will dip 'em, FOC mate...... You've got nothing to lose.
I have always wondered if that replacement tank had some sort of overspray/contamination which may be causing you the grief you're having now.
zeroed
