Back to the drawing board
Hobbo
International Rep
bits
#31 PostAuthor: Hobbo » Fri May 22, 2009 8:14 am
MIKEY
PADDERS ONLY SWEET TALKING YOU THINK HES AFTER MORE DISCOUNT ( TRUMPET ) :wink: :wink: :wink:
PHIL
International Rep
Mark Stratton
#32 PostAuthor: Mark Stratton » Fri May 22, 2009 8:45 am
My Dyna S was fried buy over voltage from a knackered regulator and this had the same symptons however mine was a bastard to start!
The pick-ups on mine have a white "goo" oozing out from underneath and apparently this is what happens when the Dyna S receives to high a voltage.
Whatever it is you have my sympathies as when it happen to me I got so pissed off with trying to start it then stripping the carbs, checking the valves clearances, checking the ignition etc etc etc that I put it in the back of the garage and left it there for a good few years. Admitted I (well Mrs S to be exact but I did do my part) have had a couple of kids since then so these took up most of the time but it is so easy to get downbeat and just ignore it.
Anyway good luck and hope you find it soon to take avantage of the good weather.
mikey
#33 PostAuthor: mikey » Fri May 22, 2009 9:18 am
Thanks mark its frustrating isnt it, cheers padders worth a go, and phil sad day but the trumpet got to go works gone bit quiet and bank manager not my best mate at the mo
mikey
#34 PostAuthor: mikey » Fri May 22, 2009 12:35 pm
Sooooooooo went out to it today and thought may as well put the dyna coils back as the other ones ginger bear gave me made no diffrence but before i put them on i thought, even though the frame was powder coated 2 years ago should i grind off the powder coating were the coils bolt on the frame, so i did not expecting it to do anything put the coils back on and it fired up on all 4 pots took it for a spin and all seems well, spoke to ralph and he said that would explain the shock through the handlebars in the rain as the coils had a bad earth but why would it do it now all of a sudden when the frame was powder coated at least a couple years ago.
#35 PostAuthor: kev edwards » Fri May 22, 2009 1:53 pm
Maybe a small amount of oxidisation around the bolt holes will cause intermitent problems , i found this out as a former electroplating technician , at times a small unoticable amount on the contact was enough to seriously impair the current flow and a failure to plate up would be the result , so to cure the problem its good old copper ease this stops the oxidisation while keeping a good current flow , just a light smear on the points of contact of the bolts should do the trick.
Regards Kev. :zap
steve bowdler
#36 PostAuthor: steve bowdler » Fri May 22, 2009 2:18 pm
Thats great news, give it a good run over the weekend then get ready for the Yorks Rally :) :)
tlc
#37 PostAuthor: tlc » Fri May 22, 2009 3:37 pm
Wouldn`t have been the same without you and Mrs Mikey on the Zed.
So hip hip hooray :D
mikey
#38 PostAuthor: mikey » Fri May 22, 2009 5:52 pm
Yep hip hip hooray been out on it this afternoon no problems let it stand for a few hours went out to it and it fired up straight away, only down side all the work i put into it this week (reckon i could strip and rebuild a set of Z1000 carbs blindfolded now :lol:) and it was something as simple as that.
mikey
#39 PostAuthor: mikey » Fri May 22, 2009 5:53 pm
Oh and yorkshire here we come!!!!!!!!!!!
