starter clutch
paulstrees
starter clutch
#1 PostAuthor: paulstrees » Tue May 26, 2009 8:45 am
Problem with slipping starter clutch.
If I tighten the bolt to 18lb the clutch slips, if tightened more it engages but the starter motor continues to run which indicates that the gear is not free
Any ideas
Paul
#2 PostAuthor: Rich » Tue May 26, 2009 2:50 pm
what engine?
paulstrees
clutch
#3 PostAuthor: paulstrees » Tue May 26, 2009 4:03 pm
z1b
#4 PostAuthor: Rich » Tue May 26, 2009 5:20 pm
Should that have a woodruff key?
Check crank and rotor taper if they have started to wear the thrust washer may be too thick and binding on the gear.
Users browsing this forum: wyrmat1 and 89 guests
