scratched disc on z1a?
- mick znone
mot time again this week, my front disc seems to have developed a scratch in the centre, the pad is grooved on the same spot. any ideas what could have caused this?the scratch is on the piston side. the clip that holds the disc in place is not scratched, so it cant be that.
- mick znone
thanks Garn, spot on mate, went straight out to check, sure enough, id over tightened the lower bolt, it was catching the disc. Ive ground down the bolt a bit and put an extra washer in. i am terrible for overzealousness with things. now i have to get some emery cloth on the disc
- mick znone
- mick znone
