Gpz 1100 UniTrak and J tanks
Keefleaf
#1 PostAuthor: Keefleaf » Sun Jun 14, 2009 11:03 am
I`ve got a Gpz 1100 UniTrak and 2 petrol tanks,both leak.
Would a 1000j tank fit? Are the frames same or similar?
#2 PostAuthor: Ginger Bear » Sun Jun 14, 2009 4:20 pm
Keefleaf,
I have both here & I will experiment tomorrow, if no one comes up with the answer before.
I would do it now, but have been instructed to fire up the barby :mmm :spit :onthep
mick znone
#3 PostAuthor: mick znone » Sun Jun 14, 2009 4:26 pm
hope you're in a fit state to fire something up Bear, don't want you burning your pinkies :ek
big green bus
#4 PostAuthor: big green bus » Sun Jun 14, 2009 6:26 pm
i am almost sure they do not fit
#5 PostAuthor: Ginger Bear » Mon Jun 15, 2009 4:08 pm
Right keefleaf, I have the answer, sadly it's NO.
It is possibe to fit the unitrak tank to the 'J' model, but not the other way round. The frame rails on the unitrak are much wider apart than the 'J', which means the 'J' tank doesn't have the clearance underneath it needs to fit the unitrak.
Keefleaf
#6 PostAuthor: Keefleaf » Tue Jun 16, 2009 8:30 am
Thanks for info.Looks like a tin of tank sealant. :(
