Carbs!
Z1000ELR
Carbs!
Hi,
My Z1000 doesnt have the original carbs. The ones fitted have an adjustment under the main body in front of the bowl & an air screw on the side. The bike is fitted with pod filters & 4-1, Jets are 117 at the moment & the needle is on the middle setting.
We are having problems getting the carbs set up, can anybody help with settings please??
Si
Si
Z1000ELR
Z1000ELR
PaulMceleney
- Chunks
Z1000ELR
1/ give them a good clean externally with cellulose thinners. It will get the crap off.
2/ set fuel heights. It looks like one of them (at least) is flooding.
Are they 28s? The only ones I have seen with both sets of screws were 26s.
Start at 1 1/4 turns out for both screws. should run at 117 main jets but take it down the dyno and have it set up there.
Z1000ELR
