Engine
MARK GB
Engine
#1 PostAuthor: MARK GB » Sun Jul 05, 2009 6:28 pm
Hi when removing the old z1 engine.Can anybody tell me which side it exit's from or will it come out of both sides ? thanks mark.
z2.john
#2 PostAuthor: z2.john » Sun Jul 05, 2009 6:33 pm
exit to the right
#3 PostAuthor: Pigford » Sun Jul 05, 2009 7:16 pm
...............and back in from the right :wink:
MARK GB
#4 PostAuthor: MARK GB » Mon Jul 06, 2009 6:03 pm
Hi ir35 thanks for the info. with a bit of look it will be out for the week end and how long it stays out. That is the big question ? who noes. :boom
kawadmb
#5 PostAuthor: kawadmb » Wed Jul 08, 2009 7:05 pm
If you want to get it out with the frame upright whip the top end off coz it's the only way you can get hold of the thing and make it light enough to lift.
Alternativelylay the bike on its side, after removing all but teh front and rear bolts and lift teh frame off the engine.
Either way taking the cam cover off will help coz there is very little clearance.
Hope this helps
Dale
PJ
#6 PostAuthor: PJ » Wed Jul 08, 2009 7:08 pm
Hi Mark, do you want a lift getting the engine out?
ted1r
po
#7 PostAuthor: ted1r » Wed Jul 08, 2009 9:09 pm
Strip the lot lay the frame with the engine on its off side and lift the frame off the engine , loads easier.
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
Re: po
#8 PostAuthor: chrisNI » Thu Jul 09, 2009 7:38 am
ted1r wrote:Strip the lot lay the frame with the engine on its off side and lift the frame off the engine , loads easier.
Ted
But drain the oil out before you do this. :mi
rickman CRR
#9 PostAuthor: rickman CRR » Thu Jul 09, 2009 7:50 am
and disconnect the clutch cable........ :D
MARK GB
#10 PostAuthor: MARK GB » Thu Jul 09, 2009 5:23 pm
Hi thanks for all the advice. Hopefully I should manage to get it out now with a bit of look with out much bother.
PJ thanks for the offer but a friend I work with will help I hope if not I will let you know thanks again.
ps have you seen the pics of the meeting on sunday. :up :up
