trick z1000
brian 450
#331 PostAuthor: brian 450 » Tue Jul 07, 2009 8:22 pm
Just got to finish cleaning the welds up and it should be ok.
tlc
#332 PostAuthor: tlc » Tue Jul 07, 2009 8:40 pm
Brian. I told you mig welding was easy............
..........but you seem to have made it look tidy as well :D
brian 450
#333 PostAuthor: brian 450 » Tue Jul 07, 2009 8:53 pm
Yes its not to bad but not very confindent yet, always worry when i first start but getting there i think
brian 450
#334 PostAuthor: brian 450 » Wed Jul 08, 2009 12:03 pm
As battery's on modern bikes are gel and they are 150mm instead of 135mm but they are a lot lower i will have to cut the side out of the box now to make it fit in :roll:
brian 450
#335 PostAuthor: brian 450 » Fri Jul 10, 2009 7:18 am
I think i will give up on posting pics of the progress of this project now and just post a pic when it is finished. As I think this thread is getting a bit boring for you all now. :bye
#336 PostAuthor: zed1015 » Fri Jul 10, 2009 7:50 am
Hey,Bri. We never get bored of looking at bits of bike .You gotta keep the pic's coming mate, Even if it's only for the benefit of those on here that can't read :lol:
steve bowdler
#337 PostAuthor: steve bowdler » Fri Jul 10, 2009 8:10 am
:su :mor whos bored not us unless your running out of film :lol:
Padders
#338 PostAuthor: Padders » Fri Jul 10, 2009 8:17 am
Agree with you Steve keep them pictures coming :D
GUYZED
#339 PostAuthor: GUYZED » Fri Jul 10, 2009 2:24 pm
PADDERS wrote:Agree with you Steve keep them pictures coming :D
Ditto, lets have more pics.
#449
Z1000A2 Z650B1
brian 450
#340 PostAuthor: brian 450 » Sat Jul 11, 2009 5:39 pm
Been busy working on the frame today, I have moved the tank pins back so the tank sits a bit further back to give me a bit more stearing lock. Also done a bit more bracing, made the rear master cylinder bracket and finished the battery box,removed all unwanted brakets and center stand mounts. removed the bottom footpeg nut on the chain side as it is in the way for the chian, I have also removed some of the frame to give me some clearance for the chain as i am not happy with how close the chain is to the frame with the off set sproket. Tommorow i will finish that off and make some rear indicator brakets and it will finally be ready for powder coat. :D :D :D :D
#341 PostAuthor: Ginger Bear » Sun Jul 12, 2009 5:57 pm
It's all sounding really good Brian, but come on, Give us some pic's.
RALPHARAMA
#342 PostAuthor: RALPHARAMA » Thu Jul 23, 2009 12:58 pm
:mor :mor
A pic say a thousand words :D
I'm defo not bored with the pix :D
Ralph Ferrand
brian 450
#343 PostAuthor: brian 450 » Thu Jul 30, 2009 7:39 am
The frame is booked in for powder coat next week, I will post some pics of the improved chain clearance. And braces tonight :wink:
brian 450
#344 PostAuthor: brian 450 » Thu Jul 30, 2009 9:46 pm
brian 450
#345 PostAuthor: brian 450 » Thu Jul 30, 2009 9:48 pm
