still spewing oil ???
mick znone
#1 PostAuthor: mick znone » Sat Jul 11, 2009 9:04 am
my phone line is down today so am on next doors broadband. could anyone let me know what the possibilities are with regards to a lot of oil coming out of the back of the block, covering my leg. could it be head gasket, if so should i ride it home? about 10 miles. could it do more damage?
Pasc
#2 PostAuthor: Pasc » Sat Jul 11, 2009 9:14 am
Mick, can you pinpoint what area at the back it's coming from ? Is it up high or down low ? Could it be the tensioner gasket ?
mick znone
#3 PostAuthor: mick znone » Sat Jul 11, 2009 9:22 am
bike not with me Pasc, picking it up later, think i should get it relayed, be on here with answers when its here. tensioner gasket gives me a glimmer of hope though mate, which i need at the moment.
#4 PostAuthor: Al » Sat Jul 11, 2009 9:24 am
If there's' a possibility that the oil had become contaminated with fuel from an overflowing carb then i would suggest that you dont drive it.
If its from the head gasket then dont drive it.
If its from anything close to the oil gallery plug then dont drive it.
If its from the breather then dont drive it.
I cant think of anywhere where i would feel that that amount of oil coming out would be inclined to make things better by driving it especially if it gets on the rear tyre.
Mick, youre in the shit so stop digging, reference your other post; drastic action is not what is called for here. Been going through this for two years now and just starting to see the end of some of it.
You have pm.
mick znone
#5 PostAuthor: mick znone » Sat Jul 11, 2009 9:25 am
is a tensioner gasket easy and cheap.
Pasc
#6 PostAuthor: Pasc » Sat Jul 11, 2009 9:30 am
Mick, a tensioner gasket is no more that a pound or two. I'ts a fairly easy job but if its your first time then make sure you understand what you are doing or have someone that knows check out the job after as do it wrong and you could end up with bent valves.
How was the bike running immediately before you noticed the oil ?
As Al said, with these symtoms don't ride it until fixed.
ps hope the op goes smoothly.
PJ
#7 PostAuthor: PJ » Sat Jul 11, 2009 9:30 am
mick z1a wrote:is a tensioner gasket easy and cheap.
yes mate, if can't get a gen one, go to a motor factors, buy some gasket paper, easy to make :D
mick znone
#8 PostAuthor: mick znone » Sat Jul 11, 2009 9:54 am
bike ran fine for about 20 miles with oil spewing, then left it at friends last night. relay should bring it back this evening.
mick znone
#9 PostAuthor: mick znone » Sat Jul 11, 2009 9:59 am
thanks guys, im trying to laugh at life, its easier that way. :rir :lar :rir :lar :hys :hys have to log off now, get back home. bt coming out this afternoon to fix my line. i appreciate you guys being on here, cheers.
PJ
#10 PostAuthor: PJ » Sat Jul 11, 2009 10:02 am
That's it mick keep smiling, I wish I was closer to give you a hand
Steve Cooke
#11 PostAuthor: Steve Cooke » Sat Jul 11, 2009 11:25 am
You may have blown the cam end rubber as that would spew oil down your leg, it's surprising sometimes how much mess you can get from even a relatively small leak. Identify the source of oil before using it.
#12 PostAuthor: kev edwards » Sat Jul 11, 2009 6:24 pm
If it's the tensioner gasket Mick , i have one you can have , just email me your address and i will send it to you , or is it possible it's coming from where the rev counter cable goes into the head ? it's suprising how far round oil travels . :)
hillbilly
#13 PostAuthor: hillbilly » Sat Jul 11, 2009 6:31 pm
have you checked weather the oil coming out smells of petrol. :wink:
mick znone
#14 PostAuthor: mick znone » Sat Jul 11, 2009 8:42 pm
got the bike back this evening, rocker cover gasket has been pushed out a bit, oil around the top. the relay guy was a mechanic of old, has owned all the 70's bikes, he said it looked like rocker cover gasket. will replace that one first guys, then see if it still spews the black stuff. i will have a closer look tomorrow, will check it for petrol smells hillbilly, need to chill now, bit fried, but a glimmer of hope has been found, thanks for the support :up
mick znone
#15 PostAuthor: mick znone » Sat Jul 11, 2009 8:44 pm
oh yeah forgot to say, what a f;ck;n day :shock:
