electrical problems
fergus
electrical problems
#1 PostAuthor: fergus » Sun Jul 26, 2009 3:22 pm
got bike through mot yesterday no probs, everything was working great so i went long run, on way back it was getting a bit dull so i flicked the lights on and the main fuse blew, managed to get home usin fuse from the lights instead.
i thought the problem would be to do with the big hole in the wire next to the fuse so iv replaced the wire and modified it so i can use modern fuses instead but as soon as i fired the bike up and hit the lights it died again, i cant see any other damaged wires so im just wondering what are the most likely causes?
all this was ok this morning cause it was raining but now the b*****d suns out!!
Big John
#2 PostAuthor: Big John » Sun Jul 26, 2009 3:30 pm
Sounds like righthand switchgear, bare wires shorting out to handlebars.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
fergus
#3 PostAuthor: fergus » Sun Jul 26, 2009 3:31 pm
thanks ill go check
tlc
#4 PostAuthor: tlc » Sun Jul 26, 2009 4:01 pm
This might be useful to check individual circuits.
Your headlight circuit should draw no more than 5 amps ! If it does then that is where your problem lies.
By the way 5 amps = 2.4 ohms. If you are lucky you will find a zero resistance reading :D
http://repair2000.com/resistance.htm
fergus
#5 PostAuthor: fergus » Sun Jul 26, 2009 4:24 pm
thank you! checked switchgear at bars an it was fine so looked where it connects to loom and found a loose connection, all fine now.
thanks for putting me on right track, i was a bit lost.
unfortunatly my girlfriend has pulled her bike apart to look at her cam chain so still cant go out to play!
