Airbox spec
coldsummer
Airbox spec
#1 PostAuthor: coldsummer » Tue Jul 28, 2009 3:12 pm
Anybody know if the airbox differs greatly between 900 models?
Reason for asking is I'm thinking of reverting back to standard (ie ditching the K&Ns) and I have a Z1b fitted with 900A4 motor, therefore not sure which model airbox to get, or if it actually makes any difference. I presume the carbs are from a 900A4 so would probably be safer the get the A4 airbox and rubbers?
Thanks for any help, Simon.
z2.john
#2 PostAuthor: z2.john » Tue Jul 28, 2009 4:45 pm
Simon,
I think you'll find that the frame is more the issue rather than engine or carbs. Z9 box might fit but suspect you will need earlier Z1 type.
John
z2.john
#3 PostAuthor: z2.john » Tue Jul 28, 2009 4:52 pm
Just seen your pics on another post of yours. Your carbs are Z1B type. You'll be needing early airbox
coldsummer
#4 PostAuthor: coldsummer » Tue Jul 28, 2009 4:55 pm
ir35 wrote:Just seen your pics on another post of yours. Your carbs are Z1B type. You'll be needing early airbox
Thanks ir35, that's really helpful!
Steve Cooke
#5 PostAuthor: Steve Cooke » Tue Jul 28, 2009 5:38 pm
A Z1 airbox will probably be easier to locate as well as there are pattern ones available at a reasonable price.
GEZ635
#6 PostAuthor: GEZ635 » Wed Jul 29, 2009 9:37 am
I have a new one for £40, which includes postage if you need one.
Gez
Gez
Garn 1
#7 PostAuthor: Garn 1 » Wed Jul 29, 2009 10:06 am
As Ir35 states " the frame is the issue" (May be!).
Both the Z1B and the 900-A4 engines have the same physical dimensions.
Both the Z1B carbs and the A4 carbs have the same physical dimensions, (albeit the Z1b (28mm) the A4 (26mm) .
The difficulty will come fitting an A4 Air-box to the Z1B frame. I'm thinking you may have trouble there. Perhaps not!
Regardz.
PS. if you can get a Z1B air-box make sure it's soft and has not shrunk in dimensions across the carbs holes.
coldsummer
#8 PostAuthor: coldsummer » Fri Jul 31, 2009 10:10 pm
GEZ635 wrote:I have a new one for £40, which includes postage if you need one.
Gez
Sorry Gez, I ordered one before seeing your post :(
