Centre stand rubbing
ARCHIE
#1 PostAuthor: ARCHIE » Thu Aug 06, 2009 9:47 pm
Am i missing something ? i can't seem to stop my stand rubbing againest the drive chain, should there be a stopper of some sort.
Archie
Theres fashion and theres passion
HowieD
#2 PostAuthor: HowieD » Thu Aug 06, 2009 9:53 pm
Archie,
yes there is like a round rubber block on the frame somewhere looked like a door stopper!!!
Can't remember where tho - RH side a bracket somewhere?
Some one else must have a picture?
hope that helps tho.....
regards
H
mick znone
#3 PostAuthor: mick znone » Thu Aug 06, 2009 10:03 pm
rubber bung on the exhaust ARCHIE.
Garn 1
#4 PostAuthor: Garn 1 » Fri Aug 07, 2009 7:31 am
Archie, the above answers are correct, if you have four into fours. However, you may have a Kerker. Mashall, V & H, Yoshimura or many others types, which are mainly "four into one" pipes and come on the LHS or RHS.
There is an adaptor you can make that limits the movement of the centre stand and mounts onto the centre stand bolts. Most others utilise the rubber exhaust bush at rear. Some have a buffer suitably mounted on a bracket at rear.
I understand the problem cause you don't see the interference while you are riding. I rode for months with the foot of the centre-stand rubbing on the chain (It was starting to wear two neat groove in the centre-stand foot.) I have since seen many centre-stands with these grooves.
Steve R
#5 PostAuthor: Steve R » Fri Aug 07, 2009 8:01 am
Take it off and save weight!!!
Harris pipe used to come with a bent metal bracket that bolted on to the pillion peg mount and stopped the chain rubbing.
ARCHIE
#6 PostAuthor: ARCHIE » Fri Aug 07, 2009 8:09 pm
Thanks alot guys
Archie
