front end shake
Keith
#16 PostAuthor: Keith » Sat Feb 24, 2007 8:56 pm
steve
think you may be right
balance ok - may be the mere taking it on and off may have cured it - who knows and can only live in hope!
will give it a run and then look at the head bearing angle
cheer
keith
#17 PostAuthor: Rich » Sat Feb 24, 2007 10:11 pm
travelingman- do you realise that tyre was developed specifically for Harley sportsters ?
Try playing about with the tyre pressures and then head bearings, but it may just be the tread style that is doing it.
Keith
#18 PostAuthor: Keith » Sat Feb 24, 2007 10:41 pm
i put a metzler perfect on as thats what was on the back when i got the bike
anyone had any experiences of the "wobble" with this one?
Keith
#19 PostAuthor: Pigford » Sun Feb 25, 2007 10:28 am
I think Zeds like the old style ribbed crossply tyres best. The ones with the tread grooves cut straight in line with wheel direction! :shock:
My monies still on tight head bearings.
Garn 1
#20 PostAuthor: Garn 1 » Sun Feb 25, 2007 12:26 pm
Travelingman, you said at the outset
"Replaced the head bearings and races can't say it really changed anything . I've got them as tight as I dare an still
have the bars fall from left to right with out binding"
You obviously had trouble with this wobble before you changed out the steering head bearings. I think you would have noticed a difference if this was the area of trouble, albeit, you over tightened the steering head.
See if you can get movement in that swing-arm. It is easy to check and you will feel it straight away!
RegardZ
travelingman
front end shake
#21 PostAuthor: travelingman » Tue Mar 06, 2007 2:42 am
Thanks for all the info guys , We are lucky over here to get original
parts . I suppose Z1 enterprise would be a good place to check for the
taper roller bearings. I'll post what find it to be .
1340fxd
I got the shakes too
#22 PostAuthor: 1340fxd » Sun May 06, 2007 5:32 am
Did you ever get this shake sorted? I got the same on my KZ1000 A2 and had it on a 100cc scooter - in both cases, if I sat further forward on the seat, the shake would stop. If I carry something on a luggage rack the shakes get worse.
Users browsing this forum: Bing [Bot] and 108 guests
