Z1000 lower arse end, mini project!
#1 PostAuthor: Pigford » Sun Feb 25, 2007 10:57 am
Well, I just had to post this for anyone interested in MODDED bikes! :wink:
I had the JMC with the rear wheel set at a forward position for ages, but loved the drag look (aka: Steve Debbens bike). So i decided to get a longer chain ( 630, not the popular 530/525, so there :!: )
Got the new chain and pulled wheel back 80mm! Soopa Doopa! :P
But............. arse end was now an inch or so higher! :cry: What with the short USD's (even with stepped yokes) the steering angle was too steep and caused it to drop & wallow a bit at lower speeds (NOT TIGHT HEADRACES!).
So me only option was to set shox back to compensate! If I dropped forks it would raise bike, defeating main object to achieve low stance!
Keeping up so far :?:
Well, being an impacient bugger, it did a crap Heath Robinson effort to see whats what!
This was good & bike handled sort of OK. Trouble was, the bottom of the shock, the bit retaining the spring was catching on me quality bracket extension (ally strip).
SO, hunted down some 1/2" ally plate & after an hour or so of drilling, filing & tapping, bodged this up:
All seems tickerty boo now. Just need to save up & have the old brackets cut off & new ones welded on! May wait til end of year to strip it down! :wink:
Surfdeneige
#2 PostAuthor: Surfdeneige » Sun Feb 25, 2007 12:54 pm
No way I would have any confidence in the shear values of them piddling little bolts. Sorry, don't want to rain on your parade but safety first!
Of course I may be wrong.
A ken fit like!
Padders
#3 PostAuthor: Padders » Sun Feb 25, 2007 1:16 pm
Have to agree there is no way I would risk riding with what looks like 2 6mm bolts holding the shock on. Get it welded mate a good shop would be able to do it without stripping out the swing arm, just the wheel.
Go on you know it makes sense. :D
phil churchett
#4 PostAuthor: phil churchett » Sun Feb 25, 2007 1:33 pm
Bloody 'ell, i would increase your life insurance if i was you :no
#5 PostAuthor: Pigford » Sun Feb 25, 2007 1:43 pm
Eeeeegads! Not the kind of positive response I was after :oops: :cry:
I have used an ally plate at the rear of the shock bolt, to tie it in to the original welded bracket!
You can see the far one through the wheel! I tapped the holes & loctited 2 x 6mm studding & fastened with 6mm nyloc nuts! I seem to remember 6mm m/s studding has a 1/4 ton shear strength. So, 2 of em each side is 1/2 ton, plus the 3mm ally plate, should be plenty!
Anyway, gonna test ride it to ACE cafe (Kwak Sunday) end of March! :wink:
Padders
#6 PostAuthor: Padders » Sun Feb 25, 2007 1:47 pm
Did not see the alloy plate behind that should stop any movement stress acting sidewards on the studs.
Keep checking the studs though, don't want to loose a club member. :D
phil churchett
#7 PostAuthor: phil churchett » Sun Feb 25, 2007 1:49 pm
Pigford wrote:Eeeeegads! Not the kind of positive response I was after :oops: :cry:
When you say "tie it in", i hope you don't mean with a cable tie :?:
Hope to see you at the Ace, [all being well]
#8 PostAuthor: Pigford » Sun Feb 25, 2007 1:51 pm
Cheers Padders! I did try to 'lumiweld' it, but such a large lump of ally, took 10 mins heating it and still to cool! Ran out of superglue, so thought bolts would do! :shock: :lol:
Ed Z1-R
#9 PostAuthor: Ed Z1-R » Sun Feb 25, 2007 7:38 pm
the bolt on jobbie is better than the strip :up
But do get it welded ASAP :D
Lawdy forbid the wooden overcoat :Oo
mikey
#10 PostAuthor: mikey » Sun Feb 25, 2007 7:51 pm
pigford
if you can get it off and take a run up to bristol
i can get it done for you no probs
#11 PostAuthor: Rich » Sun Feb 25, 2007 8:11 pm
You'd be better off leaving the swinger alone and getting shorter rear shocks. The "bracket" you have put on also looks like it may be too far back on the adjuster slot and may deform the slot with use. Is ther any room to move the top mount?
#12 PostAuthor: paul doran » Mon Feb 26, 2007 12:07 am
I have to agree with most of the comment's
a good welder is highly recommended asap
rickman CRR
#13 PostAuthor: rickman CRR » Mon Feb 26, 2007 1:09 pm
I recall seeing this variation on this shock mounting from the PMC catalogue.
http://www.excite.co.jp/world/english/w ... N&wb_dis=2
But as noted above, perhaps welding it would be a good move.
rickman CRR
#14 PostAuthor: rickman CRR » Mon Feb 26, 2007 1:11 pm
oops......PMC link
you need to page down to the swinging arm section and click "monocoque" bit
#15 PostAuthor: Pigford » Mon Feb 26, 2007 6:50 pm
Cheers guys, & Mikey, may well take you up on that offer! :wink:
Wont be for a bit tho', can't be arsed to strip rear end yet! :shock:
Users browsing this forum: No registered users and 152 guests
